1995 GT PARTS NEEDED
Old 07-23-2015, 07:54 AM
FIVE0RICKY
FIVE0RICKY's Avatar
Default 1995 GT PARTS NEEDED
Hello All
I am new here and Just purchased my first mustang, A 1995 GT 5.0 Manual Trans. It seems someone has rigged the throttle cable at the pedal (with zipties). I am starting to see why they did this becuase I cannot locate them on my own. I purchased a Lokar TC-1000EFI36 cable in hopes that it would work but from what the instructions state Ill need a T-Body cable bracket, Which no suprise I cannot find either. Is there some one who specializes in the 1994-1995 GT 5.0L cars? Im starting to be at a loss here. I need to fix this issue before moving on to the many other issues the car has. I always wanted a 1995 GT but it is turning out to be a bear. I currently work for an Exotic Car dealer in Florida and need this thing "Tip-Top". Any help you can provide Will be Great!!!!!
Thank you so much
-Ricky
FIVE0RICKY is offline
Old 07-23-2015, 03:21 PM
Boss_Hotrod
Boss_Hotrod's Avatar
That was probably done as what is known as the "throttle cable mod." If you took those off the pedal will move a considerable amount before the throttle cable even moves. It done to make the car more responsive. I did it on mine but I used an aluminum spacer. The cable is probably ok if there is no other issues with it.
Boss_Hotrod is offline
djbigskrilla
09-20-2022 01:04 AM
Urambo Tauro
12-17-2016 03:30 PM
Jskeezy84
09-08-2015 01:40 AM
Urambo Tauro
09-07-2015 12:47 PM
defarmer
08-13-2015 06:40 AM
Quick Reply: 1995 GT PARTS NEEDED
