Charging system issues
Old 07-26-2015, 11:34 AM
pbp1114
pbp1114's Avatar
Default Charging system issues
Other day broke down with an apparent bad alternator issue
alternator tested good
changed the pigtails and still nothing
Big power wire has power
Yellow wire has power
Green /red no power
White black no power
Please help ,could it be a fusable link elsewhere like at starter???
A bit puzzled fuse 18 was checke and engine compartment fuses were also checked and seem ok
pbp1114 is offline
Old 07-27-2015, 07:39 AM
88 orangepeel notch
88 orangepeel notch's Avatar
What does the alternator put out at idle and say 2000 RPM ?
And have you had the battery load tested ?
Other than that, check your cables for cuts, corrosion, and clean the grounds.
Just out of curiosity, what do you mean the car broke down ? The car wouldn't crank over at all ? Or the motor would spin over but wouldn't start ?
88 orangepeel notch is offline
Old 07-27-2015, 08:04 PM
pbp1114
pbp1114's Avatar
Default Thanks
After chasing the wiring all day and double and triple checking it ended up being another bad and tested new alternator
pbp1114 is offline
Old 07-28-2015, 06:48 AM
88 orangepeel notch
Glad to hear you found the problem, but just goes to show, new or rebuilt doesn't mean it's good. I've had it happen to me more than once.
Thanks for the update.
Granatelli Sales
03-21-2016 06:16 PM
MusicCity615
09-12-2015 07:05 AM
09-10-2015 08:39 PM
uedlose
09-10-2015 03:30 PM
09-08-2015 11:50 AM
Quick Reply: Charging system issues
