Code P2004 and P2011
Old 05-24-2015, 08:44 PM
whatsup62
whatsup62's Avatar
Default Code P2004 and P2011
Since getting car back after long tube install it has been throwing codes P2004 and P2011. What should I be looking for to correct?
whatsup62 is offline
Old 05-24-2015, 09:05 PM
jwog666
jwog666's Avatar
P2004 - Intake Manifold Runner Control (IMRC) Stuck Open (Bank 1)
Description: This DTC sets when the IMRC is commanded closed and the intake manifold runner control bank 1 (IMRC1) sensor indicates the IMRC is open.
Possible Causes:
IMRC1 circuit short to voltage
IMRC1 circuit short to SIGRTN
IMRC1 circuit short to ground
Damaged IMRC actuator
Damaged IMRC solenoid
Restricted vacuum hoses
Damaged PCM
Diagnostic Aids: The IMRC1 sensor value should change when the IMRC is commanded open or closed.
P2011 - Intake Manifold Runner Control (IMRC) Circuit Open (Bank 2)
Description: This DTC sets when an open circuit is detected in the IMRC2A circuit.
Possible Causes:
IMRC2A circuit open
Diagnostic Aids: The IMRC1 and IMRC2 sensor values should change when the IMRC is commanded open or closed
this would appear to be a wiring issuewith the imrc or a faulty imrc, check connections to make sure that they didnt unplug something or leave a harness in a position to be burnt on the exhaust, also check the vacuum lines to make sue that they are connected
jwog666 is offline
Old 05-24-2015, 09:30 PM
bluebeastsrt
bluebeastsrt's Avatar
I got the same codes on my Camaro ss. The o2 extensions had gotten to close to the headers and burnt.
bluebeastsrt is offline
Old 05-28-2015, 06:58 PM
whatsup62
whatsup62's Avatar
Found issue. Crushed IMRC actuator evidently when headers were being installed. 4-5 weeks lead time from Ford on part
BOB ROME
07-26-2023 01:54 PM
mrtrodonet
09-19-2020 03:12 PM
lincolnshibuya
12-08-2015 04:37 PM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Code P2004 and P2011
