5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
2010 headers.....help
Old 03-25-2010, 03:46 PM
mailthekid
mailthekid's Avatar
Default 2010 headers.....help
put bbk shorty headers on 2010 gt,getting cel.i have a 93 bama tune,and they said i dint need a tune for the headers.code is po135.i have already changed the o2 sensor on driver side,and cel still comes on.starting to get really frustrated...might put stock manifolds back on.any help would be appreciated.the sound is really great
mailthekid is offline
Old 03-25-2010, 09:32 PM
Blair
Blair's Avatar
When you replaced the o2 sensor did you reset your ecu? Undo the battery connection and let it sit for 10 minutes then reconnect. It takes 3-5 restarts of the car to clear the code once it is tripped, if you didn't reset and the sensor is good it would take a few starts to go away.
If that doesn't work, try checking the passenger side connection or replacing the passenger side sensor. The cel code is for o2 sensor heater failure. Maybe also check your fuses to make sure the circuit powering the sensor heater isn't blown
Blair is offline
Old 03-25-2010, 09:37 PM
discodave
discodave's Avatar
Damn, man! Way to drop some knowledge!
discodave is offline
Old 03-25-2010, 10:16 PM
10GTSTANG
10GTSTANG's Avatar
Did they turn the rears off in your tune? If not, you might want them to update it.
10GTSTANG is offline
Old 03-25-2010, 10:59 PM
smokinAMD
smokinAMD's Avatar
He shouldn't need to with shorties.
smokinAMD is offline
Old 03-28-2010, 11:13 PM
BL00DSH0T
BL00DSH0T's Avatar
With that code it is possible the o2 sensor was damaged during the install. I would check all of the connections to the o2's. And go from there.
BL00DSH0T is offline
mtgldr
02-03-2024 09:00 PM
Galactic
04-29-2019 02:56 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
Barcafut13
09-01-2015 06:08 AM
2014V6Stang
08-19-2015 03:24 AM
Quick Reply: 2010 headers.....help
