Stock pump with BAP - Cant get past 600 rwhp
Hey Guys, I have a stock pump with a KB boost a pump and 60lb injectors. I can't seem to get past 600 rwhp before I run out of fuel. Any thoughts? Is that as much as this set up will push? Thanks
Give Blow by racing or Evolution performance a call. They have plenty of 5.0's way over 600rwhp, and I believe BBR has their own fuel system for the 5.0's.
Seems a little weird though that your running out of fuel at 600. I would think it would be around 700 with a BAP
Go to 75lb injectors. That's what I have to do. Vortech's shop car is making 7** something. Can't remember off the top of my head. But they told me they had to go to 75lb injectors. They also have a boost a pump.
Maybe 80lb is too big. The 60's were definitely too small for 700's, but I would think 80's would be a little to big for the stock fuel system with a BAP to keep up with.
Take a look at this link. Evolution performance uses 75#'s in their kit with a BAP and theyre getting Produces 775 SAE hp @ 7400 rpm and 700 SAE lb.-ft. @ 4200 rpm, at 12 psi of boost
http://www.evoperform.com/shop/index...oducts_id=1150
Thanks for the help guys! It's tuned and by keeping the 80s open longer up high we got it to 6900 rpm and have it shifting there. I'm doing a triple pump system soon to make it a bit "safer" plans to build it soon and up the boost on the D1.
Dragonus18
09-09-2015 01:21 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
