5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Question about Tunes and warrenty
Old 02-08-2012, 04:46 PM
BlackGT45th
BlackGT45th's Avatar
Exclamation
Originally Posted by scottmach
That sounds real good in print but in the real world you will mostly likely lose any battle with Ford, fair or unfair.
Maybe if the person gave up. Otherwise it is a solid case for them if the part or tune didn't cause the damage.
BlackGT45th is offline
Old 02-08-2012, 05:12 PM
pdonket
pdonket's Avatar
You neglect the fact that Ford allocates many millions of dollars in lawyer fees in order to fend off attacks by anybody that doesn't have substantial leverage or funding.
My guess, by the time you defeated Ford legally and got your car fixed for free, the amount of money you've paid to do so would be more than the cost of the repairs themselves.
pdonket is offline
Old 02-09-2012, 08:50 AM
flash gordon
flash gordon's Avatar
Any tuning only provides a miniscule increase in hp. To me it's just not worth the hassle to mess with the warranty. If you can offer the repair, I would go with the charger, tuning, etc to make it worthwhile. My 0.02.
flash gordon is offline
essayons
essayons's Avatar
An aftermarket part or tune will not void the warranty automatically. The only way it will void the factory warranty is if it is the proven cause of whatever failure/damage that occurs, and that is the federal law. If you do mod your car and something goes wrong have a third party look at it and determine if the aftermarket part or tune caused the failure, if not then take it to Ford and let them know it was already determined by a mechanic it was a factory problem. Don't let any dealership tell you that your warranty is void simply by adding an aftermarket part.
when you take it to court, if Ford even bothers showing up with big guns, they will bring a mechanical engineer and an electrical engineer who will both explain that the engine and software were designed to work within a specified parameter. They will explain how the a/m tune altered those parameters, forcing the engine to operate in an unsafe parameter not intended from the factory.
Your third party mechanic will probably come back with something brilliant, such as "nuh uh".
But either way, a catastrophic engine failure in a car with an a/m tune will be an easy denial for any manufacturer, regardless of fault.
EDIT: and Ford is not just going to replace an engine under warranty because an independent mechanic says so. They have their own process for determining failure (the flow charts are posted her somewhere), and base their decision on that. You can certainly get an opinion from your own mechanic, but they will not be making warranty decisions for Ford.
essayons is offline
Old 02-09-2012, 10:09 AM
BlackGT45th
You are talking about a case in which the tune IS responsible for the damage and has caused the engine to detonate and I would have no idea why anyone would try to argue against Ford in that instance. The question at hand was will the addition of an aftermarket CAI and tune will void his warranty automatically. The answer is no by law. Should a factory part fail because of a flaw it had coming from the factory then the warranty will cover it even if the car has been modded. We all know adding aftermarket parts is a risk, which is why we look at reputable companies and tuners. Knowing how a dealership will handle it is another key. Some dealers won't mind if you have modded your car and will willingly follow that law. Others will tell you, if you ask them, that they will void it or try to anyway.
Old 02-09-2012, 03:28 PM
scottmach
scottmach's Avatar
There's more to tuning than just making more power. The throttle response is night and day and in the case of the autos it firms up the shifts nicely.
scottmach is offline
Old 02-10-2012, 07:21 AM
essayons
essayons's Avatar
I'm talking about a case where the cause of the failure is ambiguous. With a catastrophic engine failure, you'll most likely have an uphill battle trying to get your engine replaced if it can be shown you had an aftermarket ECM program installed.
essayons is offline
Old 02-10-2012, 11:02 AM
scottmach
scottmach's Avatar
Bingo! Fair or unfair if Ford has any excuse to deny a warranty they will.
Old 02-10-2012, 11:25 AM
essayons
essayons's Avatar
exactly. It may not be fair, but we need to keep our expectations realistic. If we change something as integral as the engine's electronic management, we can't expect Ford to cover it when we throw a rod through the side of the block.
essayons is offline
09-08-2015 06:25 PM
cbird1177711
09-03-2015 08:43 PM
whatsup62
09-03-2015 01:38 PM
cbird1177711
09-02-2015 08:51 PM
09-02-2015 08:40 PM
Quick Reply: Question about Tunes and warrenty
