5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Thinking about changing my gear ratio the cheap way: Changing tire height!
Old 02-17-2012, 06:37 PM
r00st
r00st's Avatar
Default Thinking about changing my gear ratio the cheap way: Changing tire height!
I am on a pretty tight budget, TRYING to save for retirement..I am only 25 but I have been spending WAY too much "fun" money and the older I get the more I realize I am SOL come time to get my SS! I am at a job that has a state pension after 8 years so that will for sure help but I need to build a cushion.
Anyway...I have a bone stock 2012 Black 6mt GT that has an owner DYING for mods. The 3.31 gears are pretty steep! I enjoy being at super low rpm's but 90% of my driving is not free way (I drive 10 miles of 55mph two lane and about 3 miles of stop/go one way to work every day). I have heard most people actually increase their city MPG with the 3.73's.
My question is this: What is the RPM difference (at say..60mph) is the:
3.31
3.55
3.73
When I get new tires later this summer (Cant swing 600 for gears AND tires) I am considering going with a 295/35/18 (26.13 height) compared to the OEM 235/50/18 which is 27.25 height. If the one inch is too drastic of a drop I could also run a 305/35/18 which is 26.4 height but tires are 100 bucks more/tire than the 295's.
I realize this is not the best way to go about things but I will take the slightly harsher ride and less sidewall to fill the fender gap to gain the 3.55-3.73 performance!
I tried playing with various calculators online but did not get far. Once I know the revolutions per mile difference between 3.31/3.55/3.73 I can then compare the tire sizes to see what RPM difference those have to try and get close to the equivalent of 3.55/3.73.
Thanks!
r00st is offline
Old 02-17-2012, 07:46 PM
clowe1965
clowe1965's Avatar
Take the larger tire diameter D, divide it by the smaller diameter d. Then multiply it by your current gear ratio. so 27.25/26.13*3.31= 3.45. Sorry bud try again. You would probably have to go to smaller rims. or really narrow profiles. Also are you using the stock rims? I didn't think that 295 or 305 widths could fit the stocks. If you are going that width then you don't have to worry about rotations already. Anyway for your use D/d*3.31=Equivalent Gear Ratio.
Also if you can figure out the amount of rubber lost per revolution in a burnout, the constant being in inches/revolution, your gear ratio during burnouts becomes integral of 0 to time of D(start)/((D(start)-(Constant of wear)*time(in minutes)*average burnout rpm))dtime just for kicks and giggles.
clowe1965 is offline
Old 02-18-2012, 08:02 AM
scottmach
scottmach's Avatar
Remember if the difference in height between the fronts and rears are to great then you'll throw your ABS off.
scottmach is offline
Old 02-18-2012, 02:58 PM
r00st
r00st's Avatar
ok thanks for the math. That does not seem like a good way to get the ratio down then!
As -1 inch on the tire is a pretty drastic change in ride/looks but not much of a gain in the gearing department. Should probably stick with tires that are as close to stock height as possible and just do gears when I get the money.
Did not think about the ABS either! Good point. Anyone know how much variance there can be front/rear before the ABS thinks your always skidding?
r00st is offline
djbigskrilla
09-20-2022 01:04 AM
jpplaw
08-22-2015 09:29 PM
Cobra4me
Carolina Regional Chapter
08-19-2015 05:54 AM
Greyshot
08-15-2015 03:32 AM
stanngg
08-12-2015 03:43 PM
Quick Reply: Thinking about changing my gear ratio the cheap way: Changing tire height!
