5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
TPMS
Old 06-14-2012, 09:21 PM
conway2004
conway2004's Avatar
Default TPMS
I recently installed new wheel and tire kit with tpms sensors from late model on my 2012 GT. When trying to use the tool to sync the new sensors I can get to learn mode but will not read sensors. Wondering what I needed to do. Tried driving the car to wake the sensors up that didn't work. I heard maybe letting all the air out of the tires, any help would be appreciated.
conway2004 is offline
Old 06-15-2012, 06:10 AM
mastertech
mastertech's Avatar
you might need to put it in training mode to retrain the sensors. Im not sure on the new ones but on the 2010's you step on the brake pedal once then turn the key on and off 3 times ending in the on position. step on brake pedal 1 time then cycle the key 3 more times ant the horn will beep and you then start with the front left, right then rear right then the left. the horn should beep when each sensor is read. I hope this works for you.
mastertech is offline
Old 06-15-2012, 06:18 AM
mastertech
mastertech's Avatar
sorry just realized that you said you can get to training mode. are you sure whoever mounted and balanced your tires put the sensors in the new wheels? i cant remember if ford uses valve stem mounted sensors or banded sensors.
Old 06-15-2012, 07:35 PM
conway2004
conway2004's Avatar
Yes they came with the sensors already installed by late model restoration.
Old 06-18-2012, 08:55 AM
Jarrod@latemodel
Former Sponsor
Jarrod@latemodel's Avatar
Sometimes when they go to sleep, you will need to deflate them, and re air them up. Once that is done you should be good to go. There is a PDF file attached to this part number. Follow this link and you can download it.
http://www.latemodelrestoration.com/...-Training-Tool
Jarrod@latemodel is offline
Old 06-18-2012, 09:47 AM
conway2004
conway2004's Avatar
If you have to deflate them the entire way couldn't that damage the rim or the seal ?
Old 06-19-2012, 08:10 AM
Jarrod@latemodel
Former Sponsor
No. If you have a compressor at the house, just deflate them 1 at a time. You wont have to take all the air our, but you will need to take most of the air out.
I had to do them same thing after i put my Drift wheels on.
spectreman
03-31-2016 09:26 PM
blueshawk
03-22-2008 11:22 AM
blueshawk
01-14-2008 12:37 PM
cartel
Wheels & Tires
10-11-2007 06:54 PM
sycd
Wheels & Tires
04-21-2007 09:52 PM
Quick Reply: TPMS
