5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
new setup. thoughts???
Old 01-23-2013, 08:43 AM
awbreyjd
awbreyjd's Avatar
Default new setup. thoughts???
Well before the next track season opens in my area of the woods we are adding some things. Going with the Boss 302r heads and the upgrade to the boss cams. Lethals duel pump fuel system, jba shorty headers (so I can keep rest of my exhaust setup). An aluminum driveshaft. Boss gauge pod for aesthetics. Then capping the build with a smaller Vortech pulley and going back to my stock 3.31 gears. I am hoping that this is enough to push my 622hp to 700+.
awbreyjd is offline
Old 01-23-2013, 05:35 PM
SpartaPerformance
SpartaPerformance's Avatar
If you're going to bother with the knuckle busting of changing headers you might as well go with American Racing long tubes, they make a BOSS specific kit with side exits like factory.
SpartaPerformance is offline
Old 01-24-2013, 08:18 AM
awbreyjd
awbreyjd's Avatar
not going through any bussle. as I am changing heads it will be easy to put the new heads on with the shorties already attached. Also I wanted headers that would bolt straight to my current setup.
awbreyjd is offline
Old 01-24-2013, 02:09 PM
clowe1965
clowe1965's Avatar
That will be a nice setup for the track. Just wondering why shorties instead of longtubes? AR and kooks both make kits that bolt directly to the boss setups, as long as the factory mid-pipe connection is being used. What is your exhaust setup that calls for shorties? Are you planning on upgrading the rotating assembly at a later date? Sorry for the questions, just curious.
clowe1965 is offline
Old 01-24-2013, 05:13 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Pretty stout setup. But you don't list any suspension mods in your sig?
UPRSharad is offline
Old 01-25-2013, 09:02 AM
awbreyjd
awbreyjd's Avatar
yea the sig only has performance parts listed. aluminum driveshaft and a safety loop. FRPP suspension kit (1inch drop). new bmr panhard bar. Slicks. UPR subframes. Still looking at roll cages.
awbreyjd is offline
bradleyb
11-27-2015 07:50 PM
Sixer4Life
10-12-2015 04:26 AM
jrrhd73must
10-02-2015 09:17 PM
ChampInSD
10-02-2015 04:55 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: new setup. thoughts???
