Which long tubes fit the best ?
I can get a good price on american racing headers, do they come with all the required hardware, or do you need new bolts and or studs? also are the gaskets good ? Or should I use a different gasket or gasket type compound ? Not all header gaskets are equal, looking for a leak free fit.
Reuse stock gaskets agreed but I used the ARH bolts, no problems 3 years later, Yes they come with everything you need.
i was thinking Kooks for the longest time because they have a great reputation but now that I took a look at AMR headers, I am starting to lean that way. It looks like they have a better rounded product compared to Kooks, better clearances, easier install, and a little cheaper. I will really have to consider them when I go the header route.
how long is the install on The AMR vs kooks if anyone has that answer? Also if I got a system w/no cats then would the o2 sensor show as not ready for emissions or would it show as ok?
Scottmach,
I'm almost 100% sure I will be going back to ARH with the O/R X pipe on the Boss and about 90% sure about going with Kooks catback. I've searched but can't find any vids with this exact set-up. The only difference is I may run the quad-x pipe. Would you happen to have a video of your set-up? Also, is the Kooks a straight through design or a chambered muffler?
sorry im a little confused on what you wrote, If they are turned off then will it read not ready or nothing at all? I am pretty sure here in az if it shows as not ready then it will fail.
Scottmach,
I have the ARH with off road x-pipe and Kooks catback. The Kooks mufflers are straight through but not super loud. Quick video I shot.
2011 5.0 Mustang GT with ARH Longtube Headers and Kooks Catback- First start - YouTube.
Just throwing a plug in for SW, same list price as arh and zero fitment issues. Pretty much the exact same header. You can pm Sleeper_gt for pricing. But hey as long as you're buying USA products we can't complain.
Let me know if I can help with either the ARH or the Kook's AB. I have a great friend that owns a shop that is a distributor for both, might be able to get you better pricing. Let me know.
Luke9222
10-22-2015 11:55 PM
