5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
NEW Drift Hi-Angle kit just RELEASED
Old 09-09-2014, 06:37 PM
Fordlover4ever
Fordlover4ever's Avatar
Thumbs up NEW Drift Hi-Angle kit just RELEASED
OMG Great Find! Finally Some one heard our Pleas!!! Thanks
RTS Stage 1 Hi Angle kit WILL give you BIG Steering angle!
DRIFT Like a PRO, RTS inc. Stage 1 Hi Angle kit are Race Proven over & over again in the Formula Drift Pro Series for the past 5 yrs!
The RTS Stage 1 Hi Angle Kit RESULTS:
Multiple Wins, Podiums, Pole Positions, Proven in USA & Internationally!
*** NEW CLIENT SPECIAL ***
We're Offering Our FIRST "10" Customers $100 off !!!
Since this is a "NEW RELEASE" Product from RTS inc.
*** Core Charge BONUS OFFER #2 ***
Send Your Original Good Condition, NONE DAMAGED Lh & Rh Spindles & Lh & Rh Lower Control Arms to RTS inc...
(see the core charge return address at bottom of page)
AND YOU WILL receive an ADDITIONAL $300.00 RTS inc. Rebate check or (Paypal refund)!
http://www.ebay.com/itm/151406533374...84.m1555.l2649
RTS inc. Stage 1 Hi Angle Kit includes:
*RTS Water Jet Modified FORD LCA's
*RTS Water Jet Modified FORD Spindles w/New FORD Lock Nuts
*Anti-Dive & Increased Caster Poly Bushing kit
(1* increase, we suggest total of 8 degrees)
*Various Sizes of Steering Rack Spacers
(to achieve MAX Angle, your total angle will vary depending on your tire & wheel width combination)
*Hi Angle Outer Toe Rod ends w/ bolt spacers
*Bump Steer Spacers (Can be adjusted to suit your cars ride height)
*Hi Angle Heim-Joint Drop Links
(Needed for MAX Angle w/NO Binding, again your total angle will vary depending on your tire & wheel width combination)
*ALL NEW Grade 8 SPEC HARDWARE
*RTS Stage 1 Kit Installs straight into your Car w/NO Real Drama
*** Once kit is installed,
A Complete Professional Alignment MUST be done BEFORE
car is driven on any road or track situation...***
(Setting Ride height, Caster, Camber, Toe, Bump Steer, Steering Rack Stops, Etc...)
Attached Thumbnails NEW Drift Hi-Angle kit just RELEASED-ebay-rts-hi-angle-kit.jpg
Fordlover4ever is offline
Old 09-10-2014, 11:52 AM
IvanRad
IvanRad's Avatar
for 3.5 grand . Ill do my own custom work.
IvanRad is offline
jwog666
12-27-2021 08:09 PM
Thunderball
15
11-22-2015 11:49 PM
flash_xx
10-16-2015 07:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: NEW Drift Hi-Angle kit just RELEASED
