5.0L V8 Technical Discussions Any questions about the 'Coyote' engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Does bigger TB need bigger MAF?
Old 08-16-2015, 05:50 PM
J7erry
J7erry's Avatar
Default Does bigger TB need bigger MAF?
I'm putting on an 85mm throttle body. Do I need to get an 85mm MAF, too? Just wondering, because I've seen them for sale. Also, will I need to update my bama tune? Thanks
J7erry is offline
Old 08-21-2015, 10:36 AM
P51C
P51C's Avatar
The bigger question about the bigger throttle body is why? Unless you are going for a screaming NA build with a CJ manifold and built long block, you aren't really gaining anything from a bigger TB.
P51C is offline
Old 08-29-2015, 08:14 PM
Lethaldosage423
Lethaldosage423's Avatar
you WILL need a tune and that will adjust your MAFS
if you get the throttle body, make sure to email bama and get a new tune BEFORE starting the car up! otherwise your car won't adjust how much fuel it needs for the larger inlet.
Unless your planning on doing some type of forced induction or are considering a cobra jet intake, i wouldn't spend the money on a throttle body. The gains that come with a Throttle body are supported by other mods such as a blower or an intake manifold and headers!
Lethaldosage423 is offline
Old 08-30-2015, 03:38 PM
J7erry
J7erry's Avatar
Thank you for the information. I appreciate it.
J7erry is offline
jwog666
12-27-2021 08:09 PM
piotrek53
10-13-2015 06:54 PM
UrS4
09-30-2015 10:13 AM
vintageaion
09-08-2015 10:45 AM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Does bigger TB need bigger MAF?
