insulation
insulation
I've heard this myth that heating and cooling insulation will work just as good as dynomat, is this true and have any you used this method? Also wouldn't it overheat your amp if it traps all heat considering its insulation imo. Any information will be very helpful thank you.
RE: insulation
Peel and Seal... that is the name of the home insulation. If your amp was also in a very tight enclosed space with no airflow it would also overheat if insulated. Thats really common sence. Heat is a byproduct of energy conversion and it also kills electroncs, why keep the bad hot air in and the good cold air out.
movielover40
09-15-2015 10:37 AM
nyjets10
10-14-2005 05:39 PM
