Replacing old antenna cable?
Old 06-27-2009, 12:25 PM
jmy2469
jmy2469's Avatar
Default Replacing old antenna cable?
Just picked up a new antenna base for my 2008 Mustang GT convertible. The old one rusted out.
What is the easiest way to install this? Do I need to remove the battery and battery tray to run the wire through the firewall? Thanks for the info
jmy2469 is offline
Old 06-30-2009, 08:54 AM
GTRedfire03
GTRedfire03's Avatar
Are you just replacing the base or the base and the lead?
GTRedfire03 is offline
Old 06-30-2009, 08:56 AM
ttocs
ttocs's Avatar
isn't it still under warrenty? Antennas suck to fix normally as they are put on early in the construction process.
ttocs is offline
Old 06-30-2009, 09:07 AM
jmy2469
jmy2469's Avatar
[QUOTE=GTRedfire03;6316353]Are you just replacing the base or the base and the lead?[/QUOTE
They do not sell just the base.You have to buy the base,cable and the lead. Replacing the whole thing.It is not under warranty anymore. I am already over the mileage
jmy2469 is offline
Old 06-30-2009, 09:17 AM
GTRedfire03
Its not goin to be fun but you can do 2 things: first just trace the old cable and run the new one the same way.
Or
Cut the old cable and soldier the new cable to the old one. That will be the easly way to do it.
What is wrong with what you have now?
Old 06-30-2009, 09:20 AM
jmy2469
jmy2469's Avatar
When I would go to the car wash, they remove the antenna. The threads on the base completely rusted away, the lead is also rusted. Had to go and buy a new one.
jmy2469 is offline
Old 06-30-2009, 09:32 AM
GTRedfire03
So are you having bad recepation problems then?
Old 06-30-2009, 09:35 AM
jmy2469
jmy2469's Avatar
Right now I have no radio antenna at all. I am using my iPhone and just play my music from there.
jmy2469 is offline
Old 06-30-2009, 10:01 AM
GTRedfire03
Well depending on have far down on the lead is rusted, will depend on where you could cut the cable and soldier the new one on.... You may just want to just rerun the new cable to the radio. Its not going to be fun, just pull the old lead out when you run the new lead. Just run it just like ford did at the factory.
5.0muscle
01-11-2016 01:17 PM
9550
10-26-2015 05:01 PM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
DoctorScary
09-09-2015 07:53 AM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Replacing old antenna cable?
