I have a 2001 Mustang V6
My Front of my Vehicle does have a place for Fog Lights.
However, in the interior the only Optional Equipment installed is a rear window defogger. The On/Off switch for the Defogger is the first of three switched. The other two switches are not in use.
From what I have found so far one of these two remaining blank switches would be for the Fog Lights if they had been an installed option.
Questions:
1. Behind the two non-functional dummy switches is there an actual switch? I mean is what I seeing just a cover over a whole in the dash or is there something behind the plug or cover?
2. How hard is it to install the lights or even a possible in dash switch? Has anyone come across a good how to do it?
I posted here about how to install fog lights to a dummy switch, you can purchase a foglight switch from www.latemodelrestoration.com that will allow you to toggle your foglights on/off. On my 02, the middle dummy is your traction controll and the dummy on the right is your foglight harnass.
