2010 GT Shaker System Problem
Old 06-11-2014, 02:32 PM
JakeR1988
JakeR1988's Avatar
Default 2010 GT Shaker System Problem
When I start my car, the dashboard monitor reads "Mustang GT" as if the radio is off, but when I push the power button nothing happens. None of the buttons on the dashboard do anything when I push them like there is some sort of internal switch that is turned off. There obviously is some sort of power going to the radio since the screen displays, so I don't believe that it's a fuse issue... Has anyone else had this problem and know how to fix it? Thanks!
-Jake
JakeR1988 is offline
Old 06-11-2014, 11:34 PM
cruisin5268d
cruisin5268d's Avatar
Always check the fuses. There's a lot of different systems that are involved here...and fuses are one of the easiest things to check. - A lot easier than pulling apart your dash to look for a loose connector.
cruisin5268d is offline
Old 06-12-2014, 02:30 AM
ticopowell
ticopowell's Avatar
Check the fuses, that is my first guess at the problem. Secondly if all the fuses are good I would check the connections at the back of the main radio box in the dash... I believe it is 6 total screws to pull it out and look, might even be able to do it with only removing 2 screws and reaching your hand back there to look. how long have you had the problem?
ticopowell is offline
Old 06-12-2014, 02:59 AM
jz78817
jz78817's Avatar
this is not necessarily so; the radio, display, and control panel are all separate modules.
jz78817 is offline
zanemoseley
09-06-2015 12:58 PM
cbird1177711
09-03-2015 08:43 PM
5.0 kevo
09-03-2015 06:24 PM
iamgobono
09-03-2015 12:37 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: 2010 GT Shaker System Problem
