Bullitt Mustangs
flywheel bolts 8 or 6?
Old 09-07-2007, 01:52 PM
bullitt15
bullitt15's Avatar
Default flywheel bolts 8 or 6?
do bullitts have 6 bolt or 8 bolt crank?
bullitt15 is offline
Old 09-07-2007, 06:24 PM
NeedStangSpeed
NeedStangSpeed's Avatar
Default RE: flywheel bolts 8 or 6?
Not sure, but if you wait about 2 weeks or so I'll let you know. All info points toward 8 on the web, but seen where somebody else had a bullitt and swears they have 6. So if your patient you will know soon.
NeedStangSpeed is offline
Old 09-08-2007, 01:57 AM
FDNYBullitt
FDNYBullitt's Avatar
I've never heard of any Bullitt being built with a Windsor motor which means you have a Romeo and a 6 bolt crank, count your valve cover bolts to be sure, good luck.
FDNYBullitt is offline
Old 09-08-2007, 10:03 AM
Donnie's GTS
Donnie's GTS's Avatar
Its a romeo block, with the tr3650/w 11inch flywheel which equals 8 bolt.
Donnie's GTS is offline
Old 09-09-2007, 02:42 AM
FDNYBullitt
The only reason I said to count your VC bolts is the very early production # of your car. Chances are 99 9/10% that you have a Romeo which has a 6 bolt crank, good luck.
Old 09-09-2007, 11:02 AM
bullitt15
bullitt15's Avatar
11 bolts on valve covers, so its romeo. thanks guys
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
junior04
09-28-2015 10:53 AM
2poor4u2
09-26-2015 11:08 AM
maestro1024
09-21-2015 02:40 PM
Quick Reply: flywheel bolts 8 or 6?
