So whenever someone sits in the front passenger seat, it tends to rub against the door panel making a squeaking noise. Does anyone else run into this problem? It only happens when someone is sitting there. The seat isn't loose when I tried to wiggle it. Could it just be bolted wrong or is this a common occurrence? Let me know guys. This noise is irritating as hell!
Crash,
I had this occur once after I had the seat out for a trip to the drag strip. I just removed it and reinstalled it and the issue went away.
GOOD LUCK getting this fixed!
mine does the same thing, its because the seat is expanded and rubbing the door, tell them to move back or forward a bit, the passenger seat is also closer to the door.
