Voltage Regulator Wiring
Installing a new voltage regulator and have more wires than I know what to do with. The voltage regulator pigtail has 2 white and 2 yellow wires. I know one yellow goes to the battery post on the alternator and 1 white wire goes to the stator post, where does the extra white and yellow wires go?
Here are some links that might help:
http://midnightdsigns.com/james/FAQs.htm
http://www.hammar.dyndns.org/~djhamm...wiring1968.htm
If I remember right with the connector entering the top of regulator,
Right post - Yellow goes to the battery post on the starter solenoid (there is a second wire that goes on this post that can go to the radio suppression condenser
Middle post - Green with red goes to a firewall connector and on to the ignition switch
Left post - White goes to the alternator wiring connector and on to the field post
To answer your question, a second yellow would do to the radio suppression condenser to help eliminate noise. I have no idea what a second white wire would do.
Edit: Correction...White goes to the field
FYI for 66-70,
The white in the F term goes to the alt FIELD,
The yellow to the A term goes to the battery side of the starter relay,
The green-red on the S term goes inside the car to the ign switched run circuit junction.
For 65,
The white-black in the S term goes to the ALT stator
The green-red in the I term goes inside the car to the idiot light.
their may or may not be a short pigtail of the A term this is for th radio suppression condenser (filter)
The links you've been provided will get you a good diagram.
jlg
Thanks for the information. When I ordered the new pigtail, it had the two extra wires that were not on my original one I took off. Did not know if they were cut off years ago or that the new one was wrong for my application. I checked out a friends and found the second yellow leading to the radio condensor, but still have not found any reason for the extra white one. I did not want to cut it off until I found the reason for that wire.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
