Any low rise 2x4 351C combos out there?
Old 07-17-2011, 11:25 AM
BlackRat
BlackRat's Avatar
Default Any low rise 2x4 351C combos out there?
Once I find the right 71 or 72 Mach 1 for me I will be looking to put together a stout 351C engine combination and would like to base it around a 2x4 edelbrock carb and low rise intake combo. I was wondering if anyone else has done this and what thier results were.
Have any pics?
What is your head and cam combo?
How is your bottom end built?
Horse power and torque numbers?
Thanks
Wade
BlackRat is offline
Old 07-18-2011, 01:21 AM
andrewmp6
andrewmp6's Avatar
The only dual 4 barrel intakes i can find for a 351c is a tunnel ram which is tall.
andrewmp6 is offline
Old 07-18-2011, 09:34 AM
BlackRat
BlackRat's Avatar
You are right. I misread the listing on summit and the only low rise 2x4 intake is for a 351W motor. I guess I will be back to a single carb since I really don't want a tunnel ram!
This is probably what I will run. http://www.summitracing.com/parts/EDL-7564/
Does anyone have any good 351C engine combos with either 2 or 4V heads? I am wanting a good lopey cam. Can I go solid lifter with pedastall style rocker mounts or do I need to have the heads machines for screw in studs?
BlackRat is offline
Old 07-18-2011, 10:11 PM
andrewmp6
andrewmp6's Avatar
I found a way http://www.pricemotorsport.com/ but not sure how much those adapters rise up the intake hood clearance might be tight.
mustangheaven
01-03-2016 11:20 AM
TCStangerv6
10-11-2015 05:57 PM
mustangheaven
10-07-2015 10:23 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Quick Reply: Any low rise 2x4 351C combos out there?
