Building 9 inch Rear End
Old 02-05-2012, 12:07 PM
frdnut
frdnut's Avatar
Originally Posted by andrewmp6
make sure the tubes are fully welded to the center most rear ends only have 2 plug welds on each side..
I think you are thinking of the 8.8 rears..I have never seen an 8 or 9 inch that wasn't fully welded.
frdnut is offline
Old 02-05-2012, 12:50 PM
BuckeyeDemon
BuckeyeDemon's Avatar
Originally Posted by frdnut
I was finally swayed into using strange 31 spline axles vs the mosers..
any particular reason? i'm running mosers (no particular reason besides it's what i ordered).
i would be surprised if there is realizable difference in 31 spline axles between the big names like moser, strange, mw when it comes to your typical heavy duty street car.
BuckeyeDemon is offline
Old 02-05-2012, 01:19 PM
Mach1BBFun
Mach1BBFun's Avatar
Thank you guys for the info excited to get the stock single trac 3.25 gears out of the car. Can't wait to get the car to the track too. Thanks for the quickperformance website too, best pricing I have seen.
Mach1BBFun is offline
Old 02-05-2012, 03:02 PM
Couper
Couper's Avatar
Curious too
Couper is offline
Old 02-06-2012, 12:56 AM
andrewmp6
andrewmp6's Avatar
I haven't had a factory 9 inch i know most gm axles they just plug welded the tubes just figured ford did it too.
andrewmp6 is offline
Old 02-06-2012, 07:24 PM
frdnut
frdnut's Avatar
I don't have any concrete evidence either way..Here is the link back to when I asked the question...Some of the guys replying are heavy duty racers and have been around the sport along time so I respect their opinions..
http://www.gearheadtalk.com/forums/s...range-or-Moser
frdnut is offline
Old 02-08-2012, 05:39 PM
BuckeyeDemon
thanks for the link!
it was nice to read the source. looks like there was two people with first hand knowledge (one appearing to be in sales if you can trust that) claiming not enough meat at the hub area on the moser (on who knows what axle).
Old 02-09-2012, 12:40 AM
boogerschnot
boogerschnot's Avatar
Good selection. Make sure you get quality bearings to back up that eaton. And find a reputable shop to set up your 3rd member, dont blow it up like I did on the first try. Lol
boogerschnot is offline
Old 06-07-2012, 11:07 PM
Mach1BBFun
Mach1BBFun's Avatar
So the order is going to be placed soon, the shop who will be setting it up will be providing gaskets, shims, etc... Anything else that should be purchased?
Here is the list:
Summit Racing SUM-720025 - Summit Racing® Leaf Spring Perches
Moser Engineering A31-71MUST - Moser Engineering Replacement Alloy Axle Shafts
Moser Engineering 9MTR - Moser Engineering Axle Bearings
Lucas Oil 10047-1 - Lucas Pure Synthetic Gear Oil x3
Detroit Locker 913A586 - Eaton Detroit Truetrac Differentials
I have decided to keep the gearing the same... So I can still drive the car on the highway....
Old 06-09-2012, 07:43 PM
BuckeyeDemon
if you are going to replace the perch then consider an upgrade like the following as opposed to a stock type replacement.
Heavy Duty Perch
Quick Reply: Building 9 inch Rear End
