Need some pictures so I can route wires correctly
Old 11-25-2014, 10:18 AM
Seadog
Seadog's Avatar
Default Need some pictures so I can route wires correctly
I have a 65 (64 1/2) with a 260 V8. Does anyone know where I can find some pictures or info on how to route and attach some of the wiring harnesses under the hood? Specifically, the harness that goes to the starter solenoid and the oil and temp sending units. Also, the ground wire from engine to firewall.
I have a wiring diagram book and it shows generally how and where to route the ignition harness but doesn't get specific on certain attachments.
Thanks.
Seadog is offline
Old 03-13-2015, 09:40 AM
Stepman
Stepman's Avatar
Sounds like what you need is an assembly manual. It will show routing, retainers,and every detail that you need.
Stepman is offline
Old 03-18-2015, 08:57 AM
bop11
bop11's Avatar
I have seen those books at the Mustang Barn, in Souderton PA. They should be on the WEB.
bop11 is offline
Old 03-21-2015, 02:00 AM
tx65coupe
tx65coupe's Avatar
I got this from CJ's
http://www.cjponyparts.com/wiring-an...-1973/p/CDW-V/
tx65coupe is offline
Old 06-13-2015, 01:40 AM
PaulLeonse
PaulLeonse's Avatar
Sounds really good It will show routing, retainers,and every detail that you need.I have some pics i will share these here.
PaulLeonse is offline
Old 06-18-2015, 12:19 PM
Seadog
Seadog's Avatar
Thanks for the comments and help. I finally found another publication that helped me nail down the proper routing.
In addition to routing I've had some fun rewiring everything under the hood and the harness to the trunk for tail lights and fuel sending unit. I've really enjoyed the work. Also removed the driver's seat and the instrument cluster so I could get to everything under the dash. Someone in the past committed a bunch of crimes under the dash! But I have everything back to stock now, including removal of some wiring that went directly to the fuse box to make this wiring hot, but not fused! The fuse box was just dangling by the wires and that's back in place too. For the first time I now have parking lights, instrument cluster lights, courtesy and glove box lights!
Seadog is offline
Ford_Dude
09-15-2015 03:25 PM
PNYXPRESS
09-14-2015 09:50 PM
jaiidutch
09-14-2015 10:29 AM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Need some pictures so I can route wires correctly
