Help Please, Correct 66 Control Arm Info Needed
Old 04-21-2015, 08:38 PM
fb1371
fb1371's Avatar
Default Help Please, Correct 66 Control Arm Info Needed
I have a 66 289 C code mustang. My problem is I carried my car in to my local shop to have new ball joints and control arms installed. When I went to pick up they said they had the wrong ones that my car had originally been a 6 cly. But it is a 2V V8 and the VIN shows this. They said the ones they had ordered were 2 inches to long. Should I remove mine myself and measure before ordering or am I missing something.
fb1371 is offline
Old 04-23-2015, 10:04 AM
69mach1377
69mach1377's Avatar
With a car this old, who knows what has been done to it. How long have you had it?
69mach1377 is offline
Old 04-23-2015, 08:29 PM
fb1371
fb1371's Avatar
about two years, went ahead and got the top ball joints replaced but three tries from the parts house and no matches on lower control arms. Going to remove my self and do some research
fb1371 is offline
Old 05-01-2015, 08:34 AM
bop11
bop11's Avatar
Does it have disc brakes? If so maybe someone did a change for Granada parts, spindles and others. IF so, the tapers are different and need inserts. They may have used the Granada upper and lower arms.
The method of camber adjustment change from shims in pre'67 to eccentric in 67 and later.
A basic front suspension kit with new arms, springs and steering components can be bought for about $350. Installation is time consuming but there are You Tube videos. Getting the spring and shock back in are the hardest parts. At least for some reason the shock seemed to be about 1/2" to short on ours.
bop11 is offline
djbigskrilla
09-20-2022 01:04 AM
JonnyBlazeGT
11-03-2015 01:10 AM
Mobiusone stang
08-24-2015 04:08 PM
inyadreems
08-21-2015 09:10 AM
defarmer
08-13-2015 06:40 AM
Quick Reply: Help Please, Correct 66 Control Arm Info Needed
