engine was still overheating
Old 08-02-2006, 03:31 AM
Musclecar fan_67
Musclecar fan_67's Avatar
Default engine was still overheating
ok, i flushed my radiator, added some radiator cleaner and water, let it run for 3 hours like it said i was supposed to do. afterwars i drove it for a little bit (maybe 20 mins) then i pulled it in the driveway and popped the hood and my overflow tank was literally BOILING over. my friend suggested we replace the thermostat, so we went and got a low temp (160 degree) thermostat and ran it agian. it seemed to be running fine. think that the thermostat was bad and i fixed it? or do u think its something deeper? thanx for all the help
Musclecar fan_67 is offline
Old 08-02-2006, 09:30 AM
dodgestang
dodgestang's Avatar
Default RE: engine was still overheating
So....you can idle in the driveway for 3 hours but you can't drive for 20 minutes?
dodgestang is offline
Old 08-02-2006, 12:05 PM
Hettar
Hettar's Avatar
More than likely, you fixed it by changing out the thermostat.
I've never tried it personally, but I hear you can take your (possibly bad) thermostat and toss it into a pot of boiling water. If it opens, it's working. If not, it's stuck (bad).
If it runs hot on you again after replacing the thermostat, the next thing to check is your hoses. If they are getting wore out, they'll collapse on you when it gets hot. If they've been there awhile, I'd suggest new hoses.
After flushing the radiator, changing the thermostat and hoses and it's still running hot, then I'd say either the radiator is so stopped up that flushing wasn't enough to unstop it, or you got a bad water pump.
Hettar is offline
Old 08-02-2006, 06:04 PM
Soaring
I ♥ Acer
Soaring's Avatar
ORIGINAL: dodgestang
I'm with Nick on this. It simply does not make sense that you can idle the car in the driveway for 3 hours without it heating up, then can only run it for 20 minutes at highway speeds before it heats up.
Soaring is offline
Nick Oliver
10-17-2018 04:22 AM
yourmom6990
09-14-2015 10:52 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: engine was still overheating
