A little progress
#22
RE: A little progress
ORIGINAL: 67Sally
I knew how to get the belt off but how do I remove the pulley?? Thanks for those pics though...I don't even have half of the brackets holding yours on.
#23
ORIGINAL: Soaring
What pulley are you talking about? The clutch pulley on the compressor, or the tension pulley? You don't need to remove the clutch pulley on the compressor. The tension pulley is held on with two bolts. Simple...
ORIGINAL: 67Sally
#26
Aluminum will Oxidize over time unless its protected.
ORIGINAL: 67Sally
ORIGINAL: slickman
If you're going to leave them natural alum, you should have put a high temp clear on them. Otherwise, they won't look like that very long..
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
09-27-2015 03:16 PM
09-25-2015 09:06 AM
