COOLING HELP !
COOLING HELP !
I have a 5.0L 302 and im using the original radiator for the 6 cylinder mustang its not keeping her cool i changed the thermostat
im getting a new fan
what radiator can i get that will keep her running cool ?
1965 ford hardtop
1965 ford hardtop
RE: COOLING HELP !
i agree. most of the parts houses will have what you need
ORIGINAL: Soaring
If you get one from a junk yard, you will be getting a used one that is probably no better than the one you have. You need to get either a new alumunum radiator, or a 3 or 4 row brass radiator.
RE: COOLING HELP !
I got the Northern aluminum 2 core. Never gets above 185 now. I also got it at a local radiator shop and installed it the same day.
Say, is that a Hurst Pro-matic 2 shifter you have? I have one and i'm having troubles with it.
