brakes locking up
RE: brakes locking up
locking up when braking or when just driving around with no brakes applied?
when brakes are applied the idea is to have equal braking force to both front wheels and both rear wheels (both fronts should lock at same time) (both rears should lock at same time) if not the car will pull to one side when brakes are applied.
Note temperatures for FR FL should be the same as well, temps for RR RL should also be equal
Gun
Gun
Yeah but now I get to tell him to check his passenger side first and see if there is brake fluid around the cylinder, to check the pads and drum, and with the drum on have someone apply the brakes and see if you can still turn the drum to see if its even working at all.
Then check driver's side too and look for the same things and do the same tests.
Gun
Gun
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:58 PM
09-25-2015 06:42 PM
