which wire goes to the choke?
RE: which wire goes to the choke?
its a holly carb 600 and its sitting on a fresh 302 originally it had one wire hooked up from the firewall to engine gauge harness it looked like it was some a## holes idea of wiring it im not sure but where does the wire that hooks up to the choke come from ? can i substitute?
Nope,
Pull the PCV valve out of the gromet and see if the "Whining" goes away. If it does, either the breather cap is blocked or you don't have a proper breather cap.
Early vintage Mustangs were not equiped with an electric choke. There is no proper provision provided (the three "P"s) in the wiring harness for an electric choke.
Here are just a couple of the many reliable choices you have.
1). install a manual choke kit (Holley has these kits available)
2). wire in a small 10A relay through the ignition circuit to power the choke.
Here are the top two "Idiots Choice Award" for "Ignorance unbecoming a classic car owner".
1). Wired the electric choke through an accessory lead.
2). Wired the electric choke off the B+ post of the coil.
Presenting these awards tonight; Vin Diesel and Mel Gibson.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
