carb filling up with gas!!!!
Old 10-08-2006, 12:30 AM
jts302
jts302's Avatar
Default carb filling up with gas!!!!
i dont understand i bought a new fuel pump and my carb still fills up with gas i have an edlebrock and when i turn the car off it drips out gas and fills up causing it to flood and it then takes like 40 min to start it again
jts302 is offline
Old 10-08-2006, 02:46 AM
rickc
rickc's Avatar
Default RE: carb filling up with gas!!!!
It sounds like the carb is the problem. The float valve doesn't sound like it is shutting off the fuel to the bowls. It could be the float level adjustment is off or the float has a hole in it which would let it sink and then not able to shut the gas off. Ot the valve could be stuck open. If the carb has been sitting a long time >6 months, this can happen.
rickc is offline
Old 10-08-2006, 05:42 PM
DGA
DGA's Avatar
Correct info--Not pump but carb needle/seat/float
Most likely a composit float but then sometimes do break down and get heavy.
DGA is offline
Old 10-08-2006, 05:43 PM
THUMPIN455
THUMPIN455's Avatar
ORIGINAL: DGA
or a stuck needle/seat.. possibly some rust lodged in it if there is no filter.
DGA is AWESOME!!! Man you know your stuff. you need to be on here more.
Still say ditch the E carb.. but yeah I am biased.
THUMPIN455 is offline
Old 10-08-2006, 06:02 PM
Colorado_Mustang
Colorado_Mustang's Avatar
If a mechanical fuel pump is on its discharge cycle when the engine shuts off, it can increase the pressure in the line to a level beyond the capability of a needle and seat to hold the fuel back, especially on the Edelbrock which can't take as much pressure as a Holley. A quality pressure regulator will offset that problem. With a mechanical pump, a deadhead style regulator will work fine. For optimum performance, install a return-style regulator.
Colorado_Mustang is offline
Old 10-08-2006, 08:15 PM
Cannonball888
Cannonball888's Avatar
I would try examining and cleaning the float bowls and valve seats first. Check for the fuel level. Install a fuel filter if you haven't got one already.
Cannonball888 is offline
Old 10-08-2006, 11:14 PM
Brandontyler65
I ♥ Acer
Brandontyler65's Avatar
well thats not a long time to sit but you could do a rebuild and also install a regualtor then you can eliminate those 2 things
Brandontyler65 is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
Sixer4Life
10-12-2015 04:26 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: carb filling up with gas!!!!
