67 i6 3 speed brake Questions
I have the car listed in the subject and want to add disc brakes to it !
Problem 1 only 5 lug conversions I have found so( going to use the cheepdisc,com ones) leaves me with 4 lug in the back.
How do i get 5 lug in the back?
Do i have to change the hole rear end if so what will fit?
Can i just change axles?
Thanks Ron
Thanks Ron
RE: 67 i6 3 speed brake Questions
If you are keeping the I6 engine, then you can just run the 4 lugs in the rear and the 5 in the front. But, if you are going to drop a V8 in it, or just want the five lugs in the rear to match the front, then you need to seriously consider either an 8" or a 9" rear end.
You might want to just keep your 4 lugs on the front with a disk brake swap. That would be the cheaper way to go instead of having to replace the rear end. Here's how.
http://www.mustangmonthly.com/howto/17279/index.html
Yes i'm going to keep the I6 and i would like to have 5 lug in the rear!
The 4 lug conversion from ssbs is only for the 65-66 I called them and checked!
Does anyone know of anybudy else that make a 4 lug kit!
Thanks For all the info!
Ron
Ron
musnicki
09-23-2015 07:11 AM
09-02-2015 08:40 PM
