My Pulleys wont line up!!!!!!
Old 11-01-2006, 12:22 PM
superdavid
superdavid's Avatar
Default My Pulleys wont line up!!!!!!
I'm getting ready to fire up the new 351W (stroked to 408) but when I went to install my alternator I noticed that the pulleys aren't lining up!!! What do I need to do? These are the old pulleys off my 289 going onto the 351 water pump... are the 351 pulleys different??
[IMG]local://upfiles/22022/8937AE7970C14FBB8DDA5765AB0F1328.jpg[/IMG]
[IMG]local://upfiles/22022/A4EEB2D193B04E6CA65E1DEDEF8C489C.jpg[/IMG]
superdavid is offline
Old 11-01-2006, 04:59 PM
deadcarnahans
deadcarnahans's Avatar
Default RE: My Pulleys wont line up!!!!!!
They are different indeed.
I read the replies to your other post and just shook my head. Don't believe everything you hear.
What water pump are you using? Is the lower hose on the left? Or right?
I'd use later 302 or 351 pullies and brackets.
[IMG]local://upfiles/36086/B1635456B55640FD92B87B23EFC30E6A.jpg[/IMG]
deadcarnahans is offline
Old 11-01-2006, 06:19 PM
grruminator78
grruminator78's Avatar
don't they make a spacer, or am I thinking about something else
grruminator78 is offline
Old 11-01-2006, 07:12 PM
Shifty101Easy
Shifty101Easy's Avatar
ive heard of people "shimming" with spacers....
Shifty101Easy is offline
Old 11-01-2006, 08:22 PM
superdavid
superdavid's Avatar
The input for the water flow is on the lower right if I'm not mistaken... Do I just need to look for a different pulley or what??? And thanks for the help!
Old 11-01-2006, 09:56 PM
dodgestang
dodgestang's Avatar
tack 4 grade 8 washers to the back of the pulley
Either that or get the long nose water pump which should move your WP pulley out one full groove....or so I have heard.
Did you change balancers?
dodgestang is offline
Old 11-01-2006, 10:01 PM
restomod66
restomod66's Avatar
Your going to have to fabricate a spacer for sure. Washers will work on the other hand.
restomod66 is offline
Old 11-01-2006, 11:25 PM
Barry70stang
Barry70stang's Avatar
I just built a 347 stroker for my car and I replaced the harmonic balancer with one from Performance Products, it required me to install a spacer. Performance Products makes the spacers. Hope this helps.
Barry
Barry70stang is offline
Old 11-02-2006, 01:41 AM
superdavid
superdavid's Avatar
Its an entire motor swap from 289 to stroked 351W. The pump itself as well as the balancer are off a 351, but the fan and pulleys are scavenged off my old 289...
Old 11-02-2006, 04:58 PM
deadcarnahans
ORIGINAL: superdavid
You have the wrong water pump and radiator.
You have come too far along to start rigging the wrong parts together now. Slow down and do it right. This is not a 289 no more.
Use 351 components and get the radiator rebuilt to match the L/H hose water pump.
GimpyHSHS
19
12-19-2023 01:12 PM
jwog666
12-27-2021 08:09 PM
TCStangerv6
10-11-2015 05:57 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: My Pulleys wont line up!!!!!!
