THE CODES????
RE: THE CODES????
The codes are normally included by the letter type in your VIN number, such as: an H or Q code. I have a 73 351C-H code engine, which basically means an 8 cylinder with low compression and a two V or two barrel carburator. You should be able to "Google" your model year and the letter code of your engine. R/John
RE: THE CODES????
Mustang Engine Codes Assembly Plant Code
Model 65 66 67 68 69 70 71 72 73 1971-73
F Dearborn
170 V R San Jose
200 T T T T T T T Metuchen
250 L L L L L 1967-73 1965-66
260 F Body Code Body Code
289 2V C C C C O1 Coupe O7
289 4V+ D O2 Fastback O9
289 4V A A A O3 Conv O8
289 HiPer K K K O4 Grande
302 2V F F F F F O5 Mach1
302 4V J
302 4V Boss G G
351 2V* H H H H H 65-70 Example
351 4V** M M M 5F08T738693
351 4V Ram Air Q Q Q 5 = year 1965
351 4V Boss R R F = Dearborn
390 2V Y O8 = Conv
390 4V S S S T = 200 eng
427 4V W 38693= Con#
428 4V P
428 4V CJ O O 71-73 Example
428 4V SCJ R R 2FO5Q223698
429 4V Boss Z Z 2 = year 1972
429 4V CJ C F = Dearborn
429 4V SCJ J 05 = Mach 1
Q= 351 4V
+ 64-1/2 -only- 223698= Cons #
* Cleveland -or- Windsor
**Cleveland -only-
Hope this helps
F Dearborn
170 V R San Jose
302 4V J
302 4V Boss G G
390 2V Y O8 = Conv
428 4V P
Q= 351 4V
**Cleveland -only-
Hope this helps
RE: THE CODES????
Sorry that didn't come out the way I wanted it to.
170 V
200 T T T T T T
250 L L L L L
260 F
289 2V C C C C
289 4V+ D
289 4V A A A
289 HiPer K K K
302 2V F F F F F
302 4V J
302 4V Boss G G
351 2V* H H H H H
351 4V** M M M
351 4V Boss R R
390 2V Y
390 4V S S S
427 4V W
428 4V P
428 4V CJ O O
428 4V SCJ R R
429 4V Boss Z Z
429 4V CJ C
429 4V SCJ J
+ 64-1/2 -only-
**Cleveland -only-
170 V
200 T T T T T T
250 L L L L L
260 F
289 2V C C C C
289 4V+ D
289 4V A A A
289 HiPer K K K
302 2V F F F F F
302 4V J
302 4V Boss G G
351 2V* H H H H H
351 4V** M M M
351 4V Boss R R
390 2V Y
390 4V S S S
427 4V W
428 4V P
428 4V CJ O O
428 4V SCJ R R
429 4V Boss Z Z
429 4V CJ C
429 4V SCJ J
+ 64-1/2 -only-
**Cleveland -only-
lincolnshibuya
12-08-2015 04:37 PM
