removing differential
Old 11-12-2006, 01:46 AM
BillyBobJoe
BillyBobJoe's Avatar
Default removing differential
Hey guys, I'm working on installing my new disc brakes fro my rear end but i need to pull out the axles. To do that, I need to pull out the diff. So I got the nuts off and I've pulled the diff off about 1/4in but its not coming all the way off. Is there any special way to pull the diff out or just keep pulling until it comes? Thanks.
BillyBobJoe is offline
Old 11-12-2006, 01:51 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
Default RE: removing differential
u dont need to remove the diff to get the axels out. in the end of the axel there are bolt behind the axel flange remove these and the axel will come out(the late model mustang u have to remove the diff cover to remove the c clips the vintage cvars dont have them)
rmodel65 is offline
Old 11-12-2006, 02:42 AM
THUMPIN455
THUMPIN455's Avatar
ORIGINAL: rmodel65
x2... the newer ownes dont know this..
there should be a hole in the axle flange to get to the bolts with a socket and extension. They come out REAL easy too.. be mindful of the seals when you pull it..
THUMPIN455 is offline
Old 11-12-2006, 02:47 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
also i had to use a slide hammer when i did my disc conversion in the rear(i couldnt budge the axle for anything!) on one side and the other came out with ease
rmodel65 is offline
Old 11-12-2006, 04:49 AM
THUMPIN455
THUMPIN455's Avatar
ah work hardened splines that swelled... or maybe something else..
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
UrS4
10-03-2015 06:23 AM
jrrhd73must
10-02-2015 09:17 PM
KingRando
10-02-2015 08:06 AM
Quick Reply: removing differential
