Wheel coating??? To coat or not to coat?
Old 12-04-2006, 10:20 PM
68SCode4speed
68SCode4speed's Avatar
Default Wheel coating??? To coat or not to coat?
Ok Guys - I just got the new Vintage 40 wheels in 15x7 (very similar to the original Torq Thrust wheel) for the '65 Mustang & put 215/60R15 Yokohamas on them. I notice that the spokes are a bead blasted/cratered effect that give them that flat look. They are clean as a whistle right now and I was wondering if there is some kind of clear coat or protective coating that I can put on them. I know that when brake dust gets on them it will be a pain to get them as clean as they are right now. (I have used Duplicolor clear coat on many things in the past and it works like a champ - I know they also make a wheel coating but I think it is colored and not clear)...
Anyone have any suggestions to help with my **** retentiveness about keeping the spokes clean??? (other than I shouldn't have bought that kind of wheel...)
68SCode4speed is offline
Old 12-05-2006, 12:19 AM
noroof66
noroof66's Avatar
Default RE: Wheel coating??? To coat or not to coat?
Post some picks, let us check them out........
noroof66 is offline
Old 12-05-2006, 12:35 AM
68SCode4speed
I haven't mounted the wheels on the car yet but did place it by the front wheel well. I'd probably tape off the shiny outside ring and then clear coat the interior areas with something that Duplicolor makes. I've had lots of luck with their stuff... Don't know how well it would stick to the aluminum though... Probably have to do a test area on the backside of one first. Here's some pics...
[IMG]local://upfiles/44155/FB1CE94269244292834C6B5F0E1166FE.jpg[/IMG]
[IMG]local://upfiles/44155/46C816BE06724FCF88AC6235AD6D4BB5.jpg[/IMG]
[IMG]local://upfiles/44155/E7D3C2FDD700411A97EDA2B305403D57.jpg[/IMG]
Old 12-05-2006, 12:41 AM
noroof66
noroof66's Avatar
Those are going to look great mounted. I've never tried any of the clear coats on rims. I would agree with trying it on the back first.
noroof66 is offline
Old 12-06-2006, 01:43 PM
68SCode4speed
Well - I spoke with the folks at Vintage Wheel Works yesterday and they said that their early wheels were uncoated but they have now begun to give them a light coat. I'll go find some of the Duplicolor clear wheel coating and then prep the wheels by cleaning the heck out of them, warm them up in the house and then give them a light coating over the whole wheel. Should help protect the finish as well keep the brake dust out of the nooks and crannies.
Old 12-07-2006, 02:10 AM
Colorado_Mustang
Colorado_Mustang's Avatar
Be careful with that polished lip. Wheel cleaning solutions will stain the aluminum.
Colorado_Mustang is offline
Old 12-07-2006, 02:15 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
wax on the wheels also www.por15.com makes a chip and scratch resistant clear i personally have not tried it though
rmodel65 is offline
Old 12-08-2006, 09:50 PM
68SCode4speed
Well - I cleaned the wheels really well and then just stood there looking at it while shaking the rattle can and thinking "This could go really well or spiral totally down the toilet." I finally said - "Let's do this" and proceeded to coat the wheels front and back. I did notice that you had to do the whole area at once and dare not stop until you got it all coated because it would show up a spot where you tried to coat over something that had already dried. I did the backside first and found that the clear coat filled in the tiny craters in the rough finish very well, +1 for keeping brake dust out. It did reduce the ultra bright trim ring shine on the outside edge of the wheel but not to the point of being bad. It darkened up, every so slightly the spoke finish but you can hardly tell and only if you saw the wheels before coating. All in all it turned out better than I expected. The stuff was Duplicolor High Temp Wheel coating in clear.
I'll post pics once they dry for a couple of days...
Old 12-08-2006, 10:05 PM
Soaring
I ♥ Acer
Soaring's Avatar
I hope it works out for you. I have had my Mag 500's for over 10 years now, and all I have ever done was use the same car wash soap as I do on the car, and they come out spotless everytime. Yeah, you are **** retentive.
Soaring is offline
jwog666
12-27-2021 08:09 PM
b8checker
10-08-2015 12:55 PM
10-01-2015 09:29 AM
b8checker
09-30-2015 07:11 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Wheel coating??? To coat or not to coat?
