Pulley question...
Pulley question...
March Pulleys
Well, i'm in the market for new pulleys and i'm going to buy march performace aluminum pulleys.
But i cann't find the correct ones that i am needing, It's 2 groove on the crank single groove on the power stearing and the alternator. The thing about it the Crank Pulley has 3 bolts, and the power stearing and alternator are single bolts for mounting them. Can anyone help me with my problem? I would greatly appreciate it.
It's V-Belt also.[:@]
RE: Pulley question...
March does have what you want, but not in a kit.
I'm guessing your WP is a single groove (don't know why they think you have a 2-groove).
1561 crank pulley
137 alternator pulley
1552 water pump pulley (1562 if you need the 2-groove)
504 power steering pump pulley
I have a March crank pulley and it's great. Beware that you'll want to find a good shop to get your belts as they won't be able to look it up in the computer. Also, March uses the narrow belts all the way around.
1561 crank pulley
Any auto parts store. You'll need to know the length/width for each belt, though. You can use a string to get an idea for the length needed. The width will be the narrow version for our cars. You can also measure that on the new pulleys (gap at the top is where you want to measure).
Just tell them the size of the belt you need. If they insist on typing something in a computer, go ahead and tell them what you have. When they bring the belts out, tell them they won't fit and then repeat the size you need.
ORIGINAL: 169mike
thank you for the information also if i were to get the pulley's where would i be able to find the belts at?
