spark plug indexing
spark plug indexing
Here is an interesting article I read. Thought some of you might be interested.
There is a lot of debate and skepticism to whether or not spark plug indexing is worth the effort. Some studies have shown 1-2% of total engine power can be lost through poor spark direction. Perhaps that does not sound like enough power to be concerned about, but consider this: Chances are that you, like the majority of enthusiasts, have spent a fair amount of money on hotter coils, ignition boxes, better plugs, ignition wires, cap and rotor, and the list goes on. In fact many heads these days boast "revised spark plug angles" and "fast burn" chambers. Heck, you probably even made the extra effort to set all your plug gaps to the exact specification. Well if you believe all those things make a difference, and they probably do, than it is only logical to think that the spark needs to face the right direction in the combustion chamber!
Indexing spark plugs has been practiced by motoring enthusiasts for many years. The technique has been used by racers to obtain maximum combustion efficiency within each cylinder, and also to maintain consistent combustion between all cylinders. The object of indexing spark plugs is to ensure that a spark plugs ground electrode is not positioned in such a way where it is shielding the spark from the fuel/air charge or impeding the flame front as it travels away from the spark plug into the chamber. The ideal position of the plug in the head is such that the gap is facing towards the valves, so that the spark is fully visible to, and aimed at, the center of the combustion chamber.
Unfortunately with today's mass produced plugs and cylinder heads, there is absolutely no assurance that when you screw in a sparkplug it ends up in the correct orientation. The majority of people take this for granted, and probably feel the minimal horsepower gains is not worth the added effort. But then again, the guys winning races aren't just following the majority!
Indexing plugs is only valid on the conventional type of "gapped" plugs that have the ground strap that extends off the threaded portion of the plug. Some new style plugs, have no grounding electrode protruding from the threaded bushing, or have multiple electrodes. These plugs are self indexing, in that their position in the chamber is the same no matter how they are installed. While this may be a small benefit, the costs of these plugs is outrageous and has not been proven to be worth the expense.
This article illustrates how indexing can be done in a relatively cheap and easy manner. Of course there are methods of using special indexing washers to also position the depth of the plug into the chamber. However we'll stick to simply attaining proper spark orientation using nothing more than a permanent marker.
On most cylinder heads, the spark plug enters the chamber at an angle. This angle places the spark plug electrode near the wall of the combustion chamber. I try to keep the grounding electrode close to the chamber wall. This ensures that the plug gap will be fully exposed to the combustion chamber and not hidden by the ground electrode. To do this, I look at the plug and note the position of the grounding electrode in relation to the plugs upper porcelain body. On the Autolites that I use, I reference the ground electrode to the lettering on the porcelain body. For instance, I might find that the grounding electrode is in line with the letter "U" in the word Autolite that is written on the plug. This is my reference that shows me where the gap is located when I screw the plug into the head. After I have referenced the grounding electrode to markings on the plug body, I screw the plug into the head, finger tight, and note the position of my reference mark. I want my reference mark to be positioned facing up and just slightly towards the corner of the exhaust port for that cylinder. When this occurs, I know the gap is fully exposed to the combustion chamber and the spark will not be shielded, by the ground strap, from the fuel charge. If I find that my reference mark does not line up within 20 degrees or so, I try another cylinder until I find a cylinder that leaves the plug in a satisfactory position. If I can't find a cylinder that allows the plug to be positioned correctly, I have no use for that plug and set it aside for another motor. I feel it is not critical to be 'dead on' with the plug orientation. Within 20 to 30 degrees, either way, should be satisfactory. The main idea is to have the gap open to the chamber, so that the air/fuel charge is exposed to the maximum spark intensity in order to facilitate a fast burn.
In order to ensure I can index a plug to all cylinders, I usually buy several sets of plugs to work with. By buying several plugs, I am hoping to get plugs that have been made at different factories, or different threading machines, by getting plugs from different 'lots'. This way I feel I have a better chance of getting a plug indexed to all cylinders. After I have indexed a plug for each cylinder, I will scratch (or engrave) the cylinder number into the plugs metal housing or one of the flat sides of the hex nut surface for proper relocation. Indexing plugs is one of those cheap and easy methods of ensuring that your ignition system is delivering the maximum energy to all the combustion chambers. After all, it is that tiny spark that gets all that horse power going. Make sure your combustion chambers can see as much of the spark as possible and you will be assured maximum power. [align=right]
[/align]
[align=left] [/align]
The proper way to install
[IMG]local://upfiles/21693/FC8AD9F363134904BBFD74E432DD5DE9.jpg[/IMG]
The improper way to install
[IMG]local://upfiles/21693/0EC6CE0BAEF6425FA4240C8A1234F08D.jpg[/IMG]
[IMG]local://upfiles/21693/0D39D1DF51F9422CB85AB3F2E7B0389E.jpg[/IMG]
[IMG]local://upfiles/21693/F89507C2F0A040EDA22548693C6B14C3.jpg[/IMG]
[/align]
RE: spark plug indexing
wow very interesting... thanks! I'll keep that in mind whenever I feel like changing the plugs...but right now their brand new and I'm not building a race motor so I'm sure I'll be fine with the normal tightening down i did lol.
[align=left]
No, not yet. That was done it the chop shop on this site. It is getting closer though. I took these pics today.
[IMG]local://upfiles/21693/475FAB9BBE0C44C09F45EAA90B5D24CB.jpg[/IMG]
[IMG]local://upfiles/21693/DFC00795F25F4627AC6AC3C335D45A2C.jpg[/IMG]
ORIGINAL: 19stang66
[/align]
Did you get your car painted valley? The one in your sig looks sweet. Thanks for the info!
[/align]
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
