How to paint Chrome
#21
RE: How to paint Chrome
Will it etch or neutralize theoxides you can't see that will lead to problems later? Just trying to learn something new. Personally I have seen some of these leave a residue of some type.
#24
ORIGINAL: Colorado_Mustang
I used steel wool on a set of chrome valve covers. Worked very well and is a good workout, too.
When I was done, I used the wool to knit a new door panel.
#26
I know it does not matter anymore, since you didn't get the part, but anyway,what I have heard is that to properly paint chromed Items, you are supposed to have the items "de-chromed" at a chrome shop. It is my understanding that the process is reversed by changing the polarityin the plating procedure. Thats just what I read somewhere a longtime ago.
#27
ORIGINAL: JMD
#28
ORIGINAL: Lumbergh
While it is an electroplating process, I don't see how just reversing the polarity would work. You might be able to remove the chrome plating using another electrochemical process but it would also require a different solution and different electrode. No personal experience withchrome plating, but I do know a bit about electrochemistry (most of which I have forgotten)from my chemistry classes in college (chemical engineering degree).
ORIGINAL: JMD
#29
I'm sure it's chemical, probably electrochemical, just not a reverse of the plating method. The only thing that would make sense to me would be a process that attacks the chrome without damaging the substrate. Could be a particular solvent or a particular solvent coupled with an electriccurrent to dissolve the chrome plating.
#30
ORIGINAL: Shifty101Easy
do you guys think that could work for my vent window frames?????????? the chrome is sorta peeling and i dont really wanna buy new ones that wont fit good or be able to buy the new repro like 5 times over by getting them re-chromed....they are good phsyically its just the idiot owner before me over sprayed them with primer and stuff....id like to just scuff and/or spot blast then spray with the chrome stuff there.....actually...come to think of it....all my chrome has overspray on it.....some windows two...... [:@]
ORIGINAL: Brandontyler65
you could try this here in the smoke color i think that might look cool it will just look like it has been anodized
mungodrums
09-28-2015 10:54 PM
