rebuilding carb
Old 10-13-2004, 11:13 PM
guitarist88
guitarist88's Avatar
Default rebuilding carb
I have a 1967 289. It has a 4 barrel haley carb. It is leaking gas and I was told i should get a book and a kit and rebuild it. I know hardly anything about cars but am eager to learn. So if anyone knows of any good kits, books, or videos on how to do stuff like this or others. and where to get them. thanks
michael thornton
draper ut
chickmagnet_m@hotmail.com
guitarist88 is offline
Old 10-14-2004, 12:34 PM
69mach1377
69mach1377's Avatar
Default RE: rebuilding carb
Rebuilding a carb is mostly disassembly, cleaning and reassembly with new gaskets and worn parts. Special tool is pressured air to blow thru holes. There is a classic book on rebuilding and the kits don't cost that much. If the flat faces are warped, fine sand paper on a piece of glass will get them flat again. GitErDun...
69mach1377 is offline
Old 10-16-2004, 12:06 AM
68GEETEE
68GEETEE's Avatar
this might be obvious, but make sure you have the carb off the engine before you start taking it apart. Lots of small screws can spell trouble if you drop one into your motor.
68GEETEE is offline
Old 10-16-2004, 07:10 PM
bob emmerich
bob emmerich's Avatar
Most of the kits have instructions in them, but they are very vague. Go to the parts store and get the kit and a book on rebuilding a carb. Be patient ang go slow. Pay attention to where things come from(check ***** and springs and such. A good rule of thumb I do is take pictures as I go so there's something to look back on just in case. It's tedious, but fairly simple once you understand how it works. Good Luck.
bob emmerich is offline
Old 10-20-2004, 01:31 PM
guitarist88
will any parts store have the kit for my car? Are there different kits for each car?
Old 10-22-2004, 07:19 PM
Mustangdemon67
Mustangdemon67's Avatar
Uh, i had this same problem, but my problem was that my holley 4 barrel was too big for my 302. I was running a 750cfm and it was wasting gas like crazy. When i downgraded to a 600cfm 4 barrel, it was much better on gas. If you really want to save gas, just get a 2 barrel.
Mustangdemon67 is offline
Dathan
10-05-2015 05:52 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Drastang
09-30-2015 03:48 AM
marc954
09-29-2015 03:05 PM
marc954
09-25-2015 06:48 AM
Quick Reply: rebuilding carb
