Ballast Resistor or not ???
Old 02-07-2007, 06:22 PM
68SCode4speed
68SCode4speed's Avatar
Default Ballast Resistor or not ???
How can I tell if my ignition system on the Mustang ('65 289 ) has a ballast resistor?? Where is it and what does it look like. (I'm installing the Pertronix II system...)
68SCode4speed is offline
Old 02-07-2007, 06:49 PM
67Sally
67Sally's Avatar
Default RE: Ballast Resistor or not ???
I'm pretty sure it's in the dizzy and it looks like this.
67Sally is offline
Old 02-07-2007, 07:10 PM
Yonco
Yonco's Avatar
my 71 has a "resistance wire" in the firewall/ under the dash that is used liek a balast reistor. My ignitor went on with the instructions of " without a balast resistor" and it worked perfect. My coil also said " use without a resitor" so i figured my car didnt have one to begin with. but then again... mines a 71-Jon
Yonco is offline
Old 02-07-2007, 07:21 PM
67Sally
67Sally's Avatar
Just get the Pertronix resistor. It isn't 100% mandatory but it's worth it.
67Sally is offline
Old 02-07-2007, 07:30 PM
Soaring
I ♥ Acer
Soaring's Avatar
Balast resistor in a 65? Never heard of one. The only resistor you have in your ignition is the pink resistor wire. You do not need a balast resistor with electronic ignition.
Soaring is offline
Old 02-07-2007, 09:51 PM
68SCode4speed
Yea - I did a search and found an article by Ford Mag that showed it was a straight forward installation. I went back and checked the ignition section of the manual and it showed no ballast resistor but I just wanted to be sure!
Thanks guys!
http://www.mustangmonthly.com/howto/...itor_ignition/
Old 02-07-2007, 09:58 PM
Soaring
I ♥ Acer
Soaring's Avatar
Thanks for the MM rendition of how to install the pertronix. I will add that to the FAQ, so it will be one of three methods. It ain't a big deal though. I put mine in in about 20 minutes even with going to the ignition switch and eliminating the pink resistor wire.
Soaring is offline
Diode Dynamics
28
05-26-2022 12:02 PM
CubanoGT
10-02-2015 10:29 AM
cbird1177711
09-03-2015 08:43 PM
HIS S-197
08-10-2015 05:47 PM
P Zero
08-15-2006 07:00 PM
Quick Reply: Ballast Resistor or not ???
