Installing heads
Old Feb 7, 2007 | 08:21 PM
white69mach1's Avatar
white69mach1
Default Installing heads
ok ive never buit a motor or put one together but im getting ready to order my 393 stroker short block and im wanting to know is installing the heads something i could posibly tackle with help for you guys on the forum
Old Feb 7, 2007 | 08:48 PM
gothand's Avatar
gothand
Default RE: Installing heads
Got a torque wrench and basic hand tools, sockets, etc.? Get a shop manual and follow the instructions and you're good to go. Pretty easy job.
Old Feb 7, 2007 | 08:53 PM
Soaring's Avatar
Soaring
I ♥ Acer
Get yourself a ratchet style torque wrench. Follow the directions for putting on the head gasket, and then tighten down the head bolts in the correct order a little bit at a time. First just snug all of them, then using the order of tightening them in the instructions, put a few pounds of torque on them, the go back and do it again, then finish with the correct torque. It's one of the easiest wrenching jobs you can do, just take your time. Give us a holler if you run into any snags. This article has some good info for you.
http://www.aa1car.com/library/2004/us70480.htm
Old Feb 7, 2007 | 09:04 PM
my77stang's Avatar
my77stang
yup yup.... what heads are you bolting onto this beast? if you have ANY doubts about how your tighting up the rocker arms give the forums a holler, but other than that heads are easy (and rocker arms arent hard its just a matter of knowing how to properly do it)
Old Feb 7, 2007 | 10:23 PM
white69mach1
the heads i have arent the best but i got a deal on them World Products Windsor Sr Cylinder Heads do you think the will work good im thinking about useing them and maybe getting them ported later on down the road
Old Feb 7, 2007 | 10:43 PM
my77stang's Avatar
my77stang
dude those heads will work JUST FINE. you'll be very happy with them, world makes great stuff
Old Feb 7, 2007 | 10:56 PM
white69mach1
only other thing is i think the heads info say says for you use with non roller motor and the shortblock im getting is a roller also im kinda of confuse on what size push rods i need
Old Feb 7, 2007 | 11:13 PM
my77stang's Avatar
my77stang
thats only referring to the springs. roller cams have a steeper ramp on the cam lobe and because of that they need tighter springs to prevent high rpm valve float. i recommend you getting the springs that are matched for your cam. you can switch them over yourself by getting a valve spring compressor from autozone or whatever your local auto parts store is (most have free tool rental)
Luke9222
Oct 22, 2015 11:55 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
