Suggestions for performance upgrades
Old 11-12-2004, 01:05 AM
razor289
razor289's Avatar
Default Suggestions for performance upgrades
I was just wondering if any body could suggest performance mods and order. I have a 68 coupe with a 289 and auto tranny. I was thinking of drums to disk upgrade then exhaust. I like it to be able to stop and breathe but after that I would like to get some opinions.
Thoughts?
Thanks
razor289 is offline
Old 11-12-2004, 10:38 AM
horseshoeing
horseshoeing's Avatar
Default RE: Suggestions for performance upgrades
Sounds good to me. Are you going to stop there or is that just a start? If you are going to do a lot of work to your motor, start with your heads. You can get alot of horses from there. Don't go cheap.
horseshoeing is offline
Old 11-12-2004, 10:39 AM
horseshoeing
SCRATCHY30 has a good start. you can look at that forum.
Old 11-13-2004, 06:09 PM
razor289
razor289's Avatar
After doing a little reading I was looking for opinions on whether to work on getting the 289 2v into something comparable to a 302 BOSS intake/carb->holley/cam and thanks to your input heads. I dont want to put more than 5K more after the exhaust and brakes. I was considering a 351W but I think I would have to replace tranny and rear end. I don't think it would the c6 but something like thrumax???
razor289 is offline
Old 11-16-2004, 08:46 PM
tinman
tinman's Avatar
351W maybe the most cost effective way to go. C-4 will work fine but I'd be thinking of a 9" rear end. With that year car, be sure and get motor mounts for a '69 Mustang w/351W or you will have hood clearance issues.......
tinman is offline
Old 11-17-2004, 11:35 AM
horseshoeing
Almost always stay will a 289. It is one of the best motors that ford has. The 289 is a quick rev motor and it is one of the fastest motors off of the line. Stay with the the 289.
Old 11-17-2004, 05:32 PM
69FECoupe
69FECoupe's Avatar
If you are just looking to upgrade to a good performing street package by all means start with your brakes and suspension. Add a good flowing exhaust and a decent intake/carb package. Don't go too big on the carb. A posi with 3.50 or so gears will make a big difference. If your pocketbook allows, install a warmer cam and aftermarket heads. This should get you to the 300 HP area. Now consider this. A stock '69 351w 4v was rated at 290 HP. The same bolt-ons would get that 351 to the 350+ HP range for virtually the same cost.
69FECoupe is offline
Old 11-23-2004, 08:19 PM
69mach1377
69mach1377's Avatar
Cubes and cams...man
69mach1377 is offline
Old 11-24-2004, 10:28 AM
69FECoupe
69FECoupe's Avatar
Amen to that.
Old 11-29-2004, 03:39 PM
cobra427302
I ♥ Acer
cobra427302's Avatar
if any one wants i have a c-6 and a c-4 available for sale 200 a piece OBO the c-6 does have a little bit of rust on the input shaft but nothing to bad , and the c-4 has a wierd bellhousing for a 6 cylinder but i can get pics if you want just email me at Cobra427302@aol.com
cobra427302 is offline
GimpyHSHS
09-18-2015 12:27 PM
vintageaion
09-08-2015 10:45 AM
M3hunter
09-05-2015 03:42 PM
Quick Reply: Suggestions for performance upgrades
