I'm kinda paranoid!
I'm kinda paranoid!
Anyhow, yes I did get a new oil pump and all, b/c mine wasn't working thus creating super high oil pressures and casuing my filters to pretty much self destruct, but I guess my engine is still running 10-15psi higher than the usual, they are supposed to run at 30-60, mine does 70-75, This shouldn't be enough to have the oil blast off the filter again is it?
Hopefully a piece of degree just messed up my 1st one when I got my engine upgraded and that 's all it was hopefully, so I am praying that the new oil pump will do the trick, if it doesn't, I dunno what I'll do....
But yes, it should be ok, your guys' thoughts?
RE: I'm kinda paranoid!
If you are really nervous or if the filter shows signs of bulging, put on a high performance oil filter. They have a thicker can and base to handle very high oil pressures. FWIW, I have run standard filters in vehicles with 80 PSI with no problems.
musnicki
09-23-2015 07:11 AM
