carb help!!
carb help!!
ive been doing some work on my mustang and i went to start it today and it back fired i think it was loud like they usually are..but then i was testiing my carb wen it wasnt running and gas is only coming out of one barrel what do i do?
RE: carb help!!
soak it in some carb cleaner, and then get the straw for the carb cleaner and stick it in the jet and spray it.... I did it to my stang when the idle was rough and then sure enough it idle'n very smooth and nice.
RE: carb help!!
A rebuild kit is probably only $25 and it only takes an hour or two to rebuild a carb. Carbs are not as scary as they seem, rebuilding is really straightforward replacement of wear-parts and making the proper adjustments.
RE: carb help!!
ORIGINAL: 390bigblock
But back to the backfire...it sounds like you have a timing issue not related to your carb. Oh, and the backfire may have blown your power valve. If so, plan on rebuilding the carb. (A replacement power valve is included in the $20 rebuild kit).
Good luck and let us know what you find.
bradleyb
11-27-2015 07:50 PM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
