Suspension Drop/Lift Kit?
RE: Suspension Drop/Lift Kit?
My 65 2+2 is at the factory setting a little higher in the front , I put new stock coil springs in the front and the four leaf in the back , but should've went with the 5 leaf instead for a stiffer ride
ORIGINAL: plainsman1876
my dad had lifting shackles on his 71 fastback in the 80s i also learned to drive in it with the *** end up in the air it handled like crap and traction was crappy in the rain it got worse.you lower a car you only lift a 4x4.
ORIGINAL: andrewmp6
I will take you opinion under consideration though!!
I got a nice rake from new suspension pieces and a slight offset in tire size.
Grab a Trak 4 leaf in the rear and 620 coils up front, with 215/60 14's in front and 215/70 14's out back. I like the stance.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
