Rear end leak
Rear end leak
I have a couple ??'s. After driving , I notice a small amount of oil dripping from where the rear end housing is, probably 4-5 drops. What could this be? Also, while driving prior to shifting from 2nd to 3rd and 3rd to 4th at higher rpm's I hear a squeking sound. This doesn't happen every time though...just occassionally. Like others I am a newbie.
Thanks,
1966 coupe
289 4 speed
[/align]
RE: Rear end leak
It could be one or a combo of three things...diff. housing gasket, pilot bearing seal, and/or pinion seal. This would be back, middle, front respectfully. You should be able to change all out yourself depending on mechanical knowledge. The best thing to do is wipe the diff down dry and let sit until you see where exactly it is leaking from. Oh, BTW, I am speaking of 9" diffs.
inyadreems
08-21-2015 09:10 AM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
92 5.0stang
08-13-2015 06:46 AM
