oil cooler
oil cooler
Iam at the point were its time to hook up the paxton to my oil pan.
Having a hard time poking a hole in the 7qt canton. lol
I have a remote oil-filter and a oil cooler I havent done anything with.
Wondering if I could tap into either return line on the remote filter or the cooler with the supercharger oil return
hate messing up that canton.
RE: oil cooler
im running a302 with an oil cooler and my oil gets about an extra month of life and my hole engine seems to run cooler. The Unit cost a big 40 bucks at my local auto parts store and actually looks pretty mean. It took meabout 30 mins to install, its worth a try unless your ride is OEM
RE: oil cooler
Thanks guys.
Nothing about my ride is oem but the roof line and maybe right door and quarter panel. lol
I checked my remote filter-filter for the internal check valve it has it in there so I can use it.
I like the idea of the oil cooler sitting out front like a cobra anyway.Ill just do some more research on this 1st.
RE: oil cooler
I am not sure what type of remote oil filter you are using but if it is the screw on adapter between the block and oil filter then all of the oil in these lines are at full pressure. The supercharger drain line should go back into a no pressure area (like side of the oil pan) and not into a high pressure. If you putthe drain line into a high pressure area it is possible the oil will not drain at all. If you are running an electric fuel punp then you can drill and tapout the block off plate for the mechanical pump and put the return line in it.
RE: oil cooler
Thanks for that info! Was wondering about the pressure thing.
Absolutely on the fuel pump block off plate ill just toss a 10 an bulk head fitting in that puppy.
Cant believe that one never came to mind.LOL I was thinking of boring out the old dipstick tube hole.
I love this site.
Just dawned on me my paxton is on the passenger side ill check routing it dont think it will work.
I love this site.
jwog666
12-27-2021 08:09 PM
