The RMP "ETI Shock Kit"
Has anyone used this set up yet? I want to upgrade my front end by droping it 1".I was going to get all my stuff from Opentrack, but now I found this coil over set up from Ron Morris Performance. Would I still have to relocate my UCA with this the RPM "ETI Shock Kit"?
All of my front end is stock.
302, 70 Fastback
302, 70 Fastback
RE: The RMP "ETI Shock Kit"
Relocating the UCA doesn't have muchto do with what spring is supporting the car or desired ride height. It has to do with how the geometry of the front suspension (camber) changes as the wheel moves up and down. This affects cornering. If you were going to do the UCA relocation purely for changing your ride height then with the ETI kit you wouldn't have to. If on the other hand you were doingthe UCA relocation for ride height AND better handling, then you still need to do the UCA relocation.
