how to remove the cowl
#22
RE: how to remove the cowl
Remove the moldings and the winshield... drill out the welds with a Uni-bit. Fit the new lower cowl in, weld, paint with POR15, reinstall top half. Not really that hard to do.
[IMG]local://upfiles/54210/4F651396299948C59D4049960427FA9E.jpg[/IMG]
[IMG]local://upfiles/54210/E0FC6CBDB50146DB92019F9BED37513C.jpg[/IMG]
[IMG]local://upfiles/54210/3F171607102342B6B69D11DCC5092498.jpg[/IMG]
#24
I soaked the heck out of all the crud over a couple days and then pulled the bolts from the paasenger side fender(bottom) and flushed them out that way and used piecies of cardboard to help sweep them along and to gettem out to the fender,,, you call all so pull the heater box in advance and "sweep" them with a picec of carboard to the passenger side vent area and reach up there with your hand and gett quite abit of crud out before soaking whats left,,,was kinda pain in the rear end but it worked and it beats paying someone help the big bucks to get the same result,,,good luck hope it helps
#26
ORIGINAL: built67
what is the actuall function of the cowl?
ford just had a bad design when it came to routing the water out the cowl and back onto the ground. that and they didn't do anything to protect the metal from rusting.
jwog666
12-27-2021 08:09 PM
