head gasket thickness?
Old 01-02-2008, 12:53 AM
SalikDDD
SalikDDD's Avatar
Default head gasket thickness?
whats the stock thickness for the gaskets on a 289? the ones on here look huge almost like someone put 2 under each head? someone told me they were .045 ? whats the thinnest i can rn without bashing anything up?
SalikDDD is offline
Old 01-02-2008, 10:40 AM
falconfixer
falconfixer's Avatar
Default RE: head gasket thickness?
Uh- if the previous owner did that - i would suspect either a warped head or block. The double gasket trick is the ghetto fix versus a deck and mill.
Be prepared for a trip to the machine shop before just re-installing them.
Why are you going in there?
falconfixer is offline
Old 01-02-2008, 01:32 PM
SalikDDD
SalikDDD's Avatar
nah i looked after i pulled one off it was just the outer edges of the gaskets flaring out - :/ oh well. - why was i going in there? head swap :| gt40p's
SalikDDD is offline
Old 01-02-2008, 06:32 PM
67mustang302
67mustang302's Avatar
I wouldn't go over .040, otherwise quench gets too large and you'll detonate. That's not true of a built engine that has negetive deck clearance, where the piston pops out of the block at TDC so you have to run a thicker gasket. On a stock engine though, you'll have several thousandths deck clearance + gasket for quench.
67mustang302 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
kevsgt
10-09-2015 10:12 PM
Dathan
10-05-2015 05:52 AM
Drastang
09-30-2015 03:48 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: head gasket thickness?
