How can i tell which transmission i have. I bought a 67 from a guy... i was told it wasa c4, but i am not forsure... are there any numbers on it, if so can you guys tell me...
Should be a C4 unless the car came with a big block. Is it a one piece case or does it have a removable bell housing? Also what is the shape of the oil pan, that is the easiest way to tell.
if it is a one piece and DOES NOT have a removable bell housing than it is NOT a C4 it would be a C6 or an AOD. However the C4 has a square oil pan, are you sure the bellhousing is not removable? This is a picture of a C4
